Motor Trike drive shaft
I have a 02 Gold Wing with a 05 motor trike kit has anyone else ever had problems with the drive shaft. I was turning off the main road on to second road it sounded like the trans had stripped out, got towed home and looked under it and drive shaft is broken. Trike has 80,000 I have owned all but 7,000 Thanks for any information.
I recall a post about MT's driveshafts a while back, but I only saved these pics for a buddy as I don't have a MT. Redesign (fatter in middle shaft, deeper splines, longer rear yoke on front U-joint, greasable too. It looks pretty robust to me.
Maybe the deeper spline engagement at the front of shaft to U-joint rear yoke is what inspired me to tighten up my own trike's fit with a bushing? Anyway, new updated shaft looks great to me. It would not fit my trike though, not with that bigger front U-joint shown.
I too have a Motor Trike, solid axle, 2005 Goldwing, kit installed in 2006. I purchased the second generation drive shaft, approx, 5 yrs ago, as a precautionary move. I believe it was $105-110, shipped to my house from Motor Trike. I now have 150,000 on the trike. No driveshaft issues, original or replacement.
Thanks for the picture. I have the old drive shaft on the trike I just bought. Going to take the drive shaft out and put guard dog paste on the splines. Going to mark it so I will get it aligned back right. Looks like I need to grab my plastic card also and order one just in case.
David
I got in touch with motor Trike inflation out the roof they told me that it would cost me$362.00 I think that is a little steep. But what can you do just bite the bullet and reach for the plastic. Thanks for your input.
Larry, if you have NOT already ordered the replacement, pm me your email address and I will send you some additional information.
I just found this thread as I went to grease the u-joints on my 03 Motor Trike and discovered that the blue driveshaft HAS no front zerk - just got off the phone with my motor trike dealer and he was saying it would be about $400 installed. Would you send me that information, too? my address is my screen name at gmail.com.
I tried to message you but for some reason I do not have permission to do so. Strange.
Ross
Ross
Email sent this afternoon. I too have not been able to PM anybody. Not sure when the "you do not have permission" issue started. Good luck.
Haven't been as active on here lately; been too busy chasing my tail & simply haven't had time. To help "shed a bit of light" I figured I would reply to this thread since cost of our driveshaft assembly has come up a few times. Also I know several shops as well as people you talk to will refer to it as a "new driveshaft design"; it was released in 2013 & has been unchanged for the past 6 years.
When we officially "released" our current driveshaft design we immediately "obsoleted" the previous version (one driveshaft for the GL1800 instead of 4 possible variations due to output shaft length changes & variances between solid axle & IRS. Plus, it's a more user friendly design for maintenance and installation). Because we gave customers no options if they had a driveshaft "issue" & HAD to purchase our "updated" version we initially priced the complete assembly so that we simply covered our expenses for production of the parts (we ate the labor cost for assembly of the components, etc).
After several years the decision was made to no longer provide the parts at cost and changed the pricing to "normal retail" which is where the price increase came into play. To the best of my knowledge we did not look at competitors pricing for driveshaft assemblies, but we did take a look at what Honda retails the front universal joint for the GL1500 for (which is what the "old style" solid axle driveshaft assy's used) for baseline pricing (front yoke from Honda retails presently for $160-175 depending on who you call).
I know that was long winded and not "needed", but figured shedding a bit of light on the behind the scenes part wouldn't necessarily hurt any either. Plus may help better "understand" the price increase a few noted in comparison to several years ago.
Knew it had been a few years, didn't realize that far back? Time flies. It is a stout looking unit.
:cool:
I still catch myself saying we did it 3 or 4 years ago.. Then I realized we're better than halfway through 2019.. I know they said time flies faster as you get older but this is getting a little out of hand; needs to slow down at least a little bit!
Posted it on the wrong spot. Put it on the right one.
David
Just bought a 97 valkyrie with the Motortrike kit and noticed it has the old style driveshaft. Wanting to get a up grade one, but just ordered a 6 degree triple tree and dealer quoted me $395.00 plus tax for the up grade driveshaft. Will have to wait to get one once I get the other stuff paid for. Just up graded the air bags and took the 235/60/15 rear tires off and installed 215/60/15. Now maybe no hydro planing with the narrower tires. I will get there one day. Little by little.
David
David
And that is how to attack it LITTLE BY LITTLE.
MT U-Joint greasing
I know this thread is old but if anyone is till having issues with the greasing of the u-joints on the trike, just let me know and I will explain the solution.
Just bought … etc …
David
So yours is (or was?) the first M-T version still using a Honda front U-joint? Many trikes will go for their whole life with a Honda OEM front U-joint. I understand wanting an upgrade, but at some point in the process of upgrading parts, chasing "weak links" … the weak link will be the transmission output shaft or some other internal transmission part.
Does adding a Trike kit affect tire size maybe to relieve pressure on drive shaft?
I have an 07 shadow aero 750. Standard size rear tire is 160/80/15. But 170/80/15 is on it, and it keeps nagging me as why is there a different tire size. The trike kit is by Trikeman. 2 bolts and unplug wiring to be on 2 wheels. Not sure whether to order rear standard size or the same size on there now.
""2 bolts and unplug wiring to be on 2 wheels."" :xzqxz: Made me google the kit. Thats training wheels, trikes have 3 wheels.
And as such, you may have seen the effect training wheels have on a bicyclist- there are times that the outer wheels may keep the center wheel from contacting.
Even on the flats, by changing the diameter of the rear tire, you change the contact pressure on the ground. So a smaller diameter tire might be GREAT for burnouts :clapping:, and a larger tire make you a bit unsteady, as the training wheels may not have the pressure on them they want.
I have NO idea if there are adjustments to the wheels to accommodate for the rear drive tire diameter changes. If not, or the previous owner didnt know, they may have found that a move up in size helped to make the bike more stable.
Just my guess as to why your tire size might be different. :Shrug: Possible that the tire vendor just had that size and it was put on as close enough.
I just clicked on it cause the thread subject was motor trike drive shaft... :D
Honda VTX1300 Motortrike rear end noise
I have a 2003 Honda VTX1300 Motortrike. I have all kinds of weird sound coming from the drive train. Understand guys say this is a noisy engine but just went through and adjusted the valves and such. Weird noises not coming from the engine but from the drive ? I was suspecting the drive shaft when I came across this post. Can anybody tell me what / how to inspect. This dang thing only has 11,000 miles on it but seems to me like it keeps getting louder...
Fred.....I can't help on the drive train...But i can Welcome you to Trike-Talk...:wave4:....
And i'm sure someone here with knowledge on your drive train problem will chime soon in with help...
Fred, Welcome to Trike Talk from West Virginia.:wave4:
MotorTrike rep. Richard will chime in.
Kickstand_Korner
