WarBird Bike
Dec 21, 2012
7
17
Washington State
WarBird Bike is my current scratch-build, theme bike using old aircraft parts as much as possible.
Powered by a 540ci, 1942 Kinner, 5-Cyl radial aircraft engine controlled by MegaSquirt EFI......
This Kinner engine originally powered a Ryan PT-22 USN Trainer Aircraft (from the days of wood spars, dope & fabric)
Stock engine specs: 160 hp continuous at 1975 rpm (with the stock updraft carb), burns 73 octane gas, has a 5.25:1 Compression ratio, 5 inch bore, with a 5.5 inch stroke, measures 45 inches in diameter and weighs 338 lbs.
This Kinner radial engine has a couple very unusual features; there is no lube oil to the heads. Grease fittings provide lubrication to the rocker arms and push rods. And instead of a 'cam ring' (like almost all other radial engines of this period) each cylinder has its own cam shaft (so there's lots of gears inside the block to give it a very unique mechanical sound).....
Wow! That is one unique trike.ThumbUpThumbUp:clapping:
How long did it take to build it?
I can think of many more questions on the rest of the drivetrain, but will hold off hoping that you'll post a build thread on it!
Thats one wild looking ride..ThumbUp.....Do you need an engineer to ride with you to watch all those gauges...:shock:..:laugh::laugh:,,,
That's one of a kind for sure. Where do you find the 73 octane gas? or is it 73 and above?
WOW!
CONGRATS on a Wild Looking Build Man, WOW!!!!!!! That Certainly LOOKS Clean & Neat! I'm VERY Impressed!
I'd LOVE to Hear That Beast RUNNING Though. I'm NOT On here a LOT, and I Don't KNOW IF We Can Put a Short Clip on here, WITH Sound, BUTT, IF It Is Possible, THAT Would Be AWESOME!
THANKS for Posting This Beaut Too War Bird!
ME
I'm sure you get a good number of "rubber neck'ers" looking at you as you ride down the street.......:clapping::clapping:
Yep very cool!
Ronnie
That is one amazing piece of machinery Warbird, would love to hear it running also.
that thing is scary looking, the dash is intmanating, but I would like to watch it run
Terry D
