loose handlebarss
Feb 19, 2016
45
12
Des Plaines, IL USA
good morning
My handlebars came loose today.
I'm hoping it is a simple tightening?
How do you get to the bolts to tighten? is there a way to open the top of the shroud?
It looks like it's an access door, but I don't want to stick a screwdriver in there to pry it off if it's not supposed to.
Any help would be appreciated.
Mcmister
Chicago
This is from the service manual for my 2017 FW
HANDLEBAR 2.15
ADJUSTMENT: FLRT
FASTENER TORQUE VALUE
Upper handlebar clamp
fastener, rear: all models
16–20 ft-lbs21.7–27.1 N·m
1. Remove trim insert from riser cover.
2. Loosen handlebar rear clamp screws one half turn.
NOTE
Measure at a right angle to the straight edge.
3. Place a straight edge across the
windshield bushings.
4. Measure from the straight edge to the front of the
handlebar just below the upper bend.
5. Rotate the handlebar in the risers until the gap measures
4 in (101.6 mm).
6. Tighten rear clamp screws to 16–20 ft-lbs (21.7–27.1 N·m).
7. Install trim insert.
Thanks for the info. Much appreciated.
I assume the insert cover is the black piece of plastic around the fork lock?
I'm told under this cover are 2 screws that need to be removed... then the shroud (riser cover?) can be removed?
from there the service instructions are clear.
Thank you again
Bar adjustments
I have 14" bars on my fw so i adjusted them to be comfortable for " me". The manual basically tells you to run a straight edge up the from legs and have a specified distance from bars to the straight edge. Not critical , in "my" humble opinion.
That cover is removed easily. You can slip a credit card under it and pry. You can then get to two of the clamp bolts.
I like the credit card approach to get cover off. I used a small screw driver and still gouged the plastic edge of cover.Have to remember that.
Thank you for photos of handlebar access plate
Tucci:
Thank you for the photos of the handlebar access plate. Those have made all the difference in the world as I had no idea what the full assembly looked like.
I'll use my plastic automobile door trim removal set to get the plate off.
My bars are not loose but appear to not be centered left to right; maybe my eyes are just crossed.
Curious about your 14" bars. What kind are they, and did you install them yourself? Need the bars a bit closer and wondering if 2" more than stock would require any longer cables or is there enough slack?
Thanks in advance!
MelT
