keikat2
90+ Posts
Hi, I am getting ready to remove my front Parking Brake cable and install a new one since the ADJUSTER HEX cover is frozen and cannot be loosened for adjustment due to rust and "gunk" on the screw threads inside the ADJUSTER HEX cover. In turn, I have read the front PB cable's removal instructions in the HD Triglide Supplement Service Manual. The Service Manual instructs there are "cable retaining rings" that must be removed from the flat metal piece at the end of the cable (see attachment) which are used to hold the rear Parking Brake cables, as well. While reading the Service Manual, I was hoping it would provide a picture of the "cable retaining rings" and their exact placement on the Pins that fits through the outside and center holes on the flat metal piece. Does anybody know what the "cable retaining rings" look like, what they are made of, what tool is used to remove them, and can I re-use them to install the new front PB cable? Thank you, Allen S.
