I have used Dyna beads in my bikes and they did a nice job, no need for wheel wts and never had any clumping. Just make sure the valve stem is in the upper half of the tire when checking tire pressure or you might get a bead stuck in the stem and let all your air out!
Valve stem should be in the 6 o'clock position when checking or adding air per instructions if I remember correctly.
I bought into the way the beads balance but never bought any of them. I bought a bottle of Daisy BB's and use them for balancing. I always use new BB's every time. Works
Do you shoot them into the tires?
Should wheel weights be removed when beads are used?
:good:YES,One of the benefits of Dyna Beads is getting rid of those stick on weights that keep coming off.
