where's fuel pump ht1500 r/m trike
May 8, 2011
755
25
Peru, IN
Leon
got a '93 1500I, want to wire the fuel pump back to original cofiguration.but where's the f/p located. got the diagram from r/s web site. thanks lb
aux fuel pump
sorry i wanted to know where the aux tank fuel pump is on the 9 gal roadsmith trike
Look underneath the trike and locate the fuel line coming out of the bottom right side of the aux fuel tank. Trace the fuel line forward and you will find a small, inline, cylindrical fuel pump mounted to the frame.
Also, click on the link below for the Roadsmith GL1500 installation instructions PDF which contains pictures and an auxiliary fuel tank kit diagram # A-100-878-D which you will find by scrolling to the very last page of the PDF.
Hope this helps.
PZ
Roadsmith GL1500 Installation Instructions
Aaaaaaaaaaaaaaa man "you rock", thank you! I also wanted to know, so now I also know... thank you! :clapping:
Ronnie
closed thread
Ronnie
sitting on the trike, remove the right rear tire. look under and aft of the aux tank. there it is..
KRC
