*DK Custom - NEW Report On External Breather System Flow w/ Testing Video & Results*
Jun 15, 2013
9,401
9,920
Red Banks, MS
A New Testing Report on External Breather System(EBS) Air Volume/Flow
Has Been Published on Our Site!
A piece taken from the report-
"When we embarked on designing our 4 Stage Catch-Can for External Breather Systems (EBS), we decided that the first order of business was to get accurate data on How Much Air passed through the stock Harley Breather Bolts, so we could design the best possible Catch-Can."
Check out the Full Report with video of testing at the link below!
Breather System Flow Testing, Results, & Video
Hi Kevin,
I am running an S&S Teardrop Air Cleaner on my Tri. Not sure which EBS might work with it. Do you have any installs of an EBS on this AC yet?
Depending on how much oil your spitting, every 5-10 thousand miles.
The Catch Can is easily emptied by holding the top with your fingers (or a wrench) and
unscrewing the bottom (can) from the top. Inside you will see:
2 pieces of Low Density foam at the bottom
3 pieces of High Density foam on the tube
3 vented separators between the top foam to slow down oil and water migration
All 5 pieces of foam can be cleaned with hot soapy water...either in place, or by
removing, then cleaning.
wzejda
