want to install catless header on 2017 tri glide.Can this be done without dropping mufflers?If mufflers do need to be removed what is the best way to remove the bolts from rear hangers seem like its pretty tight back there
You will need to drop the right muffler. You can get a combination wrench on the hanger bolts. A ratcheting box end wrench worked fine for me. It is 1/2 inch.
To make re installation of the mufflers easier, I put a stud in both rear holes of the mufflers
With this it is faster IMO to get the job done
Install a flat washer and lock washer before the nut, no need to flip the hangar or rubber insulator.
The nut will sit higher than a bolt making it easier to tighten![]()
Sorry about that. Looks like right lower and fender might be on the concrete. BUT, I got to ask.....how did you do that?Ramps involved?
.... got to ask.....how did you do that? Ramps involved?
He said 'don't ask.' But inquiring minds want to know. Next question: how did you get it back up on its wheels. Looks expensive for sure.
Believe it or not, not a scratch on it. There were a bunch of boxes to the right of my bike. Eased over on the boxes......
8~\0
what size bolt holds slip on to hangers?thanks
