Freewheeler M8 Oil Temp
Jack Klarich
Guest
Oct 11, 2016
18,130
15,125
Jacksonville, FL
Jack
I just rode 100 miles today
Air temp is 78 degrees
My Power Vision showed Engine Temp @ 288
Just for grins I stuck my thermometer in the oil tank it read 250 degrees
Next I grabbed my wife's cookie thermometer it reads the same
I am confident in the M8 engine
With 15,600 miles I have had ZERO problems with this new engine design
I am running 90 octane alcohol free gas with No ping
The knock sensors do a great job retarding the spark
I run my Love Juggs Mighty mites All the time to push the hot air away from the spark plug area The hottest part of the heads
Good information Jack & thanks for posting. I am concerned about the heat & would love to have a gauge were I could easily monitor oil temperature.
Am I correct in assuming the 288 engine temp. the Power Vision showed was a cylinder hear temp?
I need to get my 1.5" tank lift kit from Kevin ordered as I am hoping it improves the air flow/cooling in that area.
No, that is a different reading
I can display that also
It is usually a bit higher
Thank you for your inquiry. We appreciate your interest and support of our products.
The engine temp that can be displayed on the Power Vision screen is read directly from whichever temperature sensor the ECM looks at. It is NOT an exhaust temp. Depending on where you’re located, those temps are not all that uncommon for a big twin in the summer. Out here in the deserts of Las Vegas, when our ambient temperature is 110+, it is not uncommon for me to see temps as high as 350 or so in stop and go traffic. I checked with one of our HD experts, who told me to only be concerned if the temp gets to 380… At which time, they recommended to pull over, shut the bike off and let it cool down.
If you have any questions, please feel free to contact us... We're open Monday-Friday, 8am-5pm Pacific time.
Scott Webster
Technical/Sales
Training Coordinator
Dynojet Research, Inc.
2191 Mendenhall Dr., #105
North Las Vegas, NV 89081
phone: 800-992-4993
Read here also
https://www.triketalk.com/forum/threads/44717-Engine-Temperature-Sensor-on-M8-Engine
Today, air temp @83 riding 2 up PV showed ET of 300
Now I know this is a calculated temp I am not too worried
Plus checking the oil temp with 2 thermometers that read the same @ 250
I know this is a higher number, but I am confident in the miles i have already racked up that this M8 can take it;)
What would be involved in mounting a dedicated oil temp. gauge that displays where the rider can read it? Digital or analog would both be acceptable, whatever is easier.
The first picture is the oil pan, The drain plug hole to the r, the other hole has a pipe plug seen in next picture
The problem is that plug is so da-- tight
If you have a heat gun I would use that to remove the plug
You will need to get a good gauge complete with a sensor to screw in that hole
I dunno how accurate the reading is going to be I guess as good as the gauge you buy
I personally do not trust a H D gauge
  • Like
Reactions: MDO
El Cabron
