what is the best tire to put on 07 goldwing trike with4.5 degree rake
Why do you run them mounted backwards
I ran a Bridgstone BT-45 and liked it better than the MPA
The speedometer is read off the transmission/rear end of the bike. What may have changed was when you had the bike changed to a trike. The front tire has no bearing on the speedometer at all.
Tom
How did you calculate that 1MPH would = 10 per 100. If you do 100 MPH for 1 hour you will cover 100 miles and with the new tire you will cover the same 100 but it will read 101 So more like 10 per 1,000 miles
Tom
I put the MPA on my Valkyrie trike.
The improvement in handling was dramatic.
I have an on ramp I often use,it's a long sweeping right turn.
I really don't have to steer except for a slight right hand pressure, I also lean into the turn.
With the stock tire I had to really use the push pull method..
Only problem is speedo is off about 1 mile in 10,,(10%)
anyone know how to correct that??
