Handlebars - Too short for my Tri Glide
Oct 2, 2017
7
5
Houston
Hello! I’m 5’6” and need my grips closer to me. I’m just at 1000 miles and love it, but see from your posts that changing my bars may help a lot.
The Sweeper 2+2s seem to be very popular, but I’d like to avoid rewiring if possible.
Has anybody changed their handlebars to the HD Batwing Reach bars? Did they help?
If not and you’ve needed your bars closer to you, what did you change to?
I thank you for all the help the forum has provided and any comments or suggestions you may have on this.. Enjoy and be safe! :)
Hi Michelle and welcome to Trike Talk :D
A few months ago I changed out my stock bars for the Harley Batwing Reach Bars. They definitely helped. I was having to lean way forward in turns with the stock bars. No more :clapping: I'm so much more comfortable now. I'm about the same height as you.
Good luck with your search.
Batwing Reach Handlebars
Hi Carol,
Thank you for your reply. The one thing that confuses me on the description of the those bars is it says it brings the bars closer, narrower AND LOWER. Lower than the way they sit now? That doesn’t sound good. Did you experience that at all? Thanks again.
Hi Carol,
They are slightly lower. It doesn't bother me though. I love these bars. They definitely improved my Triglides handling.
Here is a pic of the stock bars from the side....
....and here is one of the Batwing Reach Bars from the side....
I hope this helps :Santa:
2+2 wide sweepers
These resolved my back and neck aches may not work for you but they really are nice for me. 2" up and 2" back and close to 4" wider like power steering. DSC00124.JPGDSC00132.JPGDSC00137.JPGDSC00268.JPGDSC00552.JPGDSC00554.JPG
Hi Michelle,
Run down to your dealer
Most have a seat and handle bar set up so you can try different set ups
Seems to me most trikes you can get by with up to 4 inches of height and or pull back with out any major changes
Welcome to Trike Talk
Thank you everyone. Sweepers are sweeping the poll!
Arnie - you’ve had both and good to know you prefer the sweepers. I was originally going with those. Do you mind me asking if my height of 5’ 6” is a quite a bit shorter then yours? Just to get a reference.
i like the idea of my dealership having ways to have test setups, but I guess they don’t have it at mine. Or they didn’t offer.
It’s now snowing in Texas! I guess I won’t be riding anytime soon. Well it’s Texas, I could be riding next week in 80* weather! :AllGood:
I'm 5'8". The 2+2 sweepers helped cure my sore shoulders & neck issues. When on trips I can ride 8+ hrs with no problems at all.
Not snowing here, but only 20deg. Enjoy tour your Texas riding!
Another vote for 2+2s
These are the narrow ones, about the same width as the ones I took off. I'm 5'8" with a 29" inseam.
I've since rotated them up, more toward the windshield.
Sit on your bike, put your arms where you feel comfortable, NOW the tricky part
Have someone snap a picture
You can see your posture now and get an idea of how much change you need
You can now also measure your bars to see what the difference is This may help in you choosing new bars
I have a '17 T G Ultra, and had the same problem. I replaced the stock bars with the 2 + 2 bars. There was no rewiring required. All the stock hoses, throttle, and wires fit just right, with no exceptions. It really does feel like "power steering" as said on some other post. I did it my self, in about 1.5 hours, it is really easy to do.:clapping::):Santa:
Fred, did you have to get extra wires or brake & clutch for controls ?
I have been busy my 09' I needed a longer clutch cable hydraulic clutches on newer models need nothing else. Bronx bill used wire extenders but not sure they were an absolute need.
Brake lines and wiring was all good for my year of Manuf. these bars for me were a God send had I not found them I was contemplating selling the trike. Night and day difference no back or shoulder pain my right wrist is locked from a crash with a collie dog in 1974 the straighter angle also helped me. The wider bars add leverage like power steering good luck on your choice. :D travel safe Fred
:santa-chimney::santa-stuck::singing-snowman:
Thanx Fred, I did put the HD pull backs on when bike was new, not sure how the + 2 would be. (wider ? ) I think wider would make for easier steering. I will have to measure the width on these I have & then find width on + 2.
Sweepers are 31.94" wide OEM are less than 30" 2+2 is 2" higher and 2" back You can see how mine are,DSC00553.JPGDSC00556.JPG I have them pushed just about as far forward as the inner faring will allow. I have a tank lift and used the sweepers because they are convex in design to make sure they cleared the tank.
Im thinking wider more leverage
Some times too tall is not so much better?
I like my stock bars on my Freewheeler, tho I may rotate them up just a bit, most days I can steer on the flats with just a couple fingers on the end of the ls grip
Jack I cannot say enough good things about these style bars not "apes" not some wild design just a little more reach and raised up just enough to straighten posture. A few inches wider as you know a little means a lot on leverage. A little straighter angle on the grips for my stiff wrists. :good: Ride safe Fred
P.S. I'm 5'8" short arms I did install Avon large grips to help with my grip.
Ron A
