1800 front brake question.
Replacing front brake pads and found on the left side the two outside pistons are not working. The one in the center works when the front brake lever is used. This is on a Roadsmith Trike. I know the anti dive is disabled. Would that cause those two pistons not to work?
Thanks Dannie
Thanks Dannie
Yes. The outside two on the left caliper are the rear linked pistons. The center on the right caliper is the rear linked piston. :xszpv: :xszpv:
