Attention Please - Mr. Trike
Dec 21, 2012
566
598
Indianapolis, IN
Bob
Mr. Trike,
Please advise, a
t what intervals should the differential oil be changed? Miles/Age ?
Thank you for your response.
God bless,
Bob
I am not by any means Mr. Trike. He started The Trike Shop in the 70's which has become Roadsmith. If your trike is a Roadsmith conversion, here is a manual for shaft driven Honda trikes: http://www.roadsmithtrikes.com/media/docs/sroadsmith-14102111140.pdf
Looking at your profile, though, it seems you have a CSC conversion. You might check and ask on Trike Talk CSC forum: http://www.triketalk.com/forum/forums/391-California-Sidecar
Someone may be able to answer your question, and the kit manufacturers usually have a rep that monitors the forum.
Thanks to all.
I posted again on cs​c.
Below is a link to CSC's Owner's Manual. All though their is probably no reason to, there is nothing wrong with doing that service more frequently.
http://californiasidecar.com/pdf/Manual_-_2017.pdf
Rear end oil should be changed after the first 3 months or3,000mi., whichever comes first. Rear end oil should then bechanged every 12 months or 20,000mi. Use only NON-synthetic80W-90 GL-5 gear oil. The differential case should contain no morethan 1 qt of gear oil.
At higher odometer readings, repeat at frequency intervals established here.
