Jack Klarich
Guest
Check this out for oil pumps on Twin Cams, This should be done any time U open up the cam chest, and or you have high oil leaks
Use on Twin Cam 1999 - Present
Use this tool to correctly align the oil pump to the cam plate on Twin Cam models.
Refer to Harley-Davidson® service manual for proper oil pump installation.
1. When securing the oil pump to the cam support plate, install two
alignment tools through the cam support plate and into the oil pump
mounting holes. The self centering screws will align the remaining,
oil pump holes.
2. Secure two OEMallen screws to the unoccupied oil pump mounting
holes and torque to Harley-Davidson® manual.
3. Replace the alignment tools with the remaining OEM hardware and
torque to Harley-Davidson® specifications.
9100110
MULTI-PURPOSE ALIGNMENT TOOL
This tool number is from J and P, you can get it cheaper if need be so check around. If u r real handy u can make 1
Hope this helps
oil pump holes.
9100110
Hope this helps
