Lawless
40+ Posts
Received my J&S Trike jack the other day, and decided to try it out today.
Took me a little while to get it set up correctly under the trike so it wasn't touching the left side exhaust, and that it wasn't pushed too far in or pulled too far out.
Finally started raising it after about 15 minutes of positioning.
To say it was scary would be an understatement.
It was a real pucker factor of 10.
The jack performed flawlessly, and the trike was very sturdy.
I checked my rear shock bolts, and the lower right one was really loose so I torqued it to specifications, and checked every bolt I could get to.
Hopefully it will get easier to use the jack as time goes by.
Do any of you use the jack, and if so any hints or recommendations for use ?
As for the jack it is made really well, and does what J&S says.
