Has any one added backup lights to the GL1800 trike?
Would sure like to know how you did it.:clapping:
Wish i had some kind of back-up lights [Automatically turned on] on my Tri-Glide, Quite often when backing out of a spot people don't notice that you are backing out and will drive right by as you are rolling back... The Spyder i had would when in reverse automatically turn on the 4 ways, And that got most peoples attention And they would let you back out....Especially if their looking for a parking space them self.....:Shrug:
WHY !!!
Did you need them when you had two wheels?
What are the advantages of backup lights on a Trike?
Wish I had a BACKUP BEEPER AND JAKE BRAKE. Talk about attention.:gah:And while your at it, how bout adding a Backup Beeping Horn. :Shrug:
That would get peoples attention.
thanks greg, worked perfectly, now i can back into my garage at night and miss all the stuff. I pulled it in when it was 2 wheels. Sometimes you have to think outside the box!for reverse lights, below are instructions and a diagram most trikes use. The reverse circuit only includes the 4 wires coming from the rely at the lower right.
Note: These reverse lights only work after the rev/on switch is pushed to the on position, and the start button engaged. In other words, as the trike begins to backup.
1. Route the three wires for the reverse lights from the body to the left side of the motorcycle frame towards the battery box.
2. Locate the black boot above the starter solenoid. There will be a red two prong connector that has a yellow wire with a red tracer, and a brown wire with a red tracer.
3. Using a scotchlok crimp connector, crimp the yellow wire with the red tracer from the trike body wiring harness to the yellow wire with a red tracer in that connector.
4. Route the red wire with the fuse holder to the (+) positive side of the battery.
5. Route the white wire in the trike body wiring harness to the negative side of the battery.
For reverse lights, below are instructions and a diagram most trikes use. The reverse circuit only includes the 4 wires coming from the rely at the lower right.
Note: these reverse lights only work after the Rev/on switch is pushed to the on position, and the start button engaged. In other words, as the trike begins to backup.
3. Using a Scotchlok crimp connector, crimp the yellow wire with the red tracer from the trike body wiring harness to the yellow wire with a red tracer in that connector.
5. Route the white wire in the trike body wiring harness to the NEGATIVE side of the battery.
