Article: DK Custom Products Premium Tank Lift Kits for Tri-Glides and Harley Conversions
Looking for a friend, he wants after market arm rests for a 2015 TriGlide, can't seem to find them. Kury has some under development, but you know what that means. Pls comment to <a href="mailto:bikerbillwms@yahoo.com">bikerbillwms@yahoo.com</a>
how does the seat fit when you raise the back of the tank?
Unfortunately I couldn't use the lift. Handle bars got in the way. But if you use the deluxe lift, there will be no change in the fuel gauge; because it lifts the front as well as the back.
Nuc
What do they do for the fuel gauge float? Does the gauge continue to read true or there a sight change?
If it is a 14 or later, there is no effect on the gas gauge. On 13 and earlier models it may change the fuel gauge a little (1/4 of a gallon)..sometimes that will make them more accurate, other times less. :laugh:
Nuc
If you are running stock bars or any kind of apes, you should be able to use a 1.5" lift. It is important to loosen the rear tank bolts and slide the tank all the way back. Doing that should give clearance for the bars. Only time that would not work is if you have the bars adjusted way down...sort of like a cafe placement.
2" DK Tank lift with rear too! 2015 Freewheeler
The 2" Tank lift fits great on my 2015 along with the rear tank spacers It looks real good!
My dealer service Mgr noticed it right away and comments on it every time he sees it!
