Stage 5 Tire Shredder on Freewheeler
Just completed stage 5 on my 2015 Freewheeler. Went from 76 horsepower to 118 horsepower with 130 lbs of torque. A real nasty machine now. Pull the front wheels off the ground, guess I will have to mount some wheel extensions on back to keep it from going backwards and over. Put Vance/Hines headers with M/F extensions. Its got a real bad case of heart burn the way it sounds.
Since most of us probably don't know what Stage 5 entails, I know I don't, maybe you could give us a run-down on what was done to it to produce those numbers.
Stage 5
4.0" cylinders, SE CNC-Ported Cylinder Heads, matching 10.2:1 forged high compression pistons and rings, SE-259 cams, perfect-fit pushrods, high-capacity roller tappets, cam cover gaskets, heavy duty clutch spring, high flow fuel injectors
Screamin' Eagle® Super Tuner
58mm air cleaner and Cam Drive Retention
Just a few items to name.
Also, can you include an estimate of the cost?
Not cheap, but impressive after its done.
Never heard of a Stage 5 still haven't, what you call a stage 5 is a motor built out to drag and will be very unreliable for everyday use. Nice if you got the money and don't mind the expense it will bring.:AGGHH:
Not knockin' what you did, but you should've just put a big S&S motor on it with a new tranny. Same desired effect without 'taking down' your engine, just replacing it with one that was built that way.
Of course unless you're the mechanic that did all the work yourself.
The cams and compression are not that radical and would be fine on a street engine. It also sounds like it has a 58mm throttle body, which will work fine on a street application. Sounds more like a healthy Stage II or IV, like Sloride's Road Glide trike.
Steve, can you post a dyno sheet on your engine?
Thank you for this post, trikeharley. I've been contemplating this upgrade the last few days. Yes, it's pricey, but I think the net gains may well be worth it. I'm not necessarily looking to win races, but the extra power for passing on the interstate would be nice. The torque would be the real benefit for me, as I and my wife together are not light weight on our FW. The extra grunt would be greatly appreciated, especially when taking off. My only concern is my warranty. As this is an HD product, and if done by HD technicians, I imagine it would not void the warranty, however...one never knows.
I digress found what they are selling as a stage 5 http://www.harley-davidson.com/store/screamin-eagle-110ci-stage-v-tire-shredder-kit
for the money I agree would of been better to just put in an S&S..
Your post got me to digging, alien (a dangerous thing when my wallet is involved :laugh:) I checked the S&S website and found the lowest cost engine was over $6000 plus a few extras that would need ordered. The Stage V looks to be around $2700 plus a few extras, it seems. Are my numbers right? If so, the Shredder looks like a solid option. Too, I assume (we all know what can happen when we assume), can be done by an HD shop, and, hopefully, keep your warranty in tact, if you have warranty on the trike. If warranty is an issue, it looks to me like the Shredder is the way to go. If not, and especially if one can do the work himself/herself, the S&S looks truly sweet. Being new to this, I may be way off base, and apologize if I have spoken incorrectly.
Aaron
Aaron
You have a valid point with the labor and extras involved price would be higher.Still below an S&S. Good point on the warranty since you have a dealer wrench doing the work and not the factory. It just seemed false their calling it bolt-on, on the site since the hole top end is replaced. Not what i would call bolt-on. IMO;)
I'd prefer the S&S, alien, there's no doubt about that. Unfortunately, I have no doubt my warranty would be flushed, and I would need someone to do the install and tune; I can barely change a light bulb. I called my local shop and asked about the 110 upgrade and my warranty, and was told they needed to check with HD to verify if my warranty either stays intact or is modified in some way. I agree wholeheartedly that the advertising is practically an outright lie. I am not a mechanic, but even I know this is nowhere near a simple bolt-on kit. Technical knowledge and specialized tools are needed for a job like this, and I suspect there have been a few poor novices that mistakenly assumed it would be a simple undertaking.
If you don't need to remove the engine and machine the cases, it's a bolt-on installation. Some jobs are just more involved.
stage 5
Your purchase a Stage 5 from Harley Davidson. Perhaps a visit to the dealer will help you.
Stage 5 completed by your dealer will keep your warranty in tack. Anything else will void your warranty.
Even with extras, you are way under a S&S with about the same power.
I said I was wrong and stood corrected, as far as a stage 5 if that's what Moco calls it that's fine for them. Most people think of bolt on as something anyone pretty much can do. I don't think most could just bolt that kit in and not be in trouble. Plus the labor to Harley so you keep your warranty. Most would waited until warranty was gone to upgrade like that. But then I just finished a few months back rebuilding my old Evo myself so what do I know. It seems you have a good build there from the dealer, makes a big difference. When you first posted Stage 5 you sounded like you did it, was kind of vague in the first post my bad..
I have so much to learn about modifying Harley's, Clint. I simply cannot fathom that installing this kit could be considered a bolt-on. I think of bolt-on as intake, exhaust, grips, etc. This kind of work, though, I'd be so in over my head I'd resemble the Three Stooges rolled into one.
Thank you much, trike. I'm waiting on a call with a quote from my local shop. I suspect with the Stage V, intake, exhaust and tuner plus labor, I'm going to be out about $5000. Pricey and I'll never get it back, but, man, the oomph and grunt capabilities are nearly too much to ignore.
No ones more die hard Harley than me, so says my pard.
but if ya want grunt i h ave a 425hp trike, that Ive never rode. My pard has tho. Selling it, and i have a 99 twin cam e glide trike, a 69 shovel trike, all low on power compared to my v8 trike or urs.
I understand the desire, i truly do, seems Harley could offer a trike like that already with engine in place and jus pick Ur pocket some more and go on.
But alas a tech has to make a living, so there goes that idea. I would love a test ride tho, mmm, might motivate me to invest in the insanity. :AGGHH:trike chev front right.jpg
But alas a tech has to make a living, so there goes that idea. I would love a test ride tho, mmm, might motivate me to invest in the insanity. :AGGHH:Attachment 39827
Holy smokes, Downtown! That is one heck of a trike! Pretty sure it'd be way too much for me, though. I'd doubtless put it into the side of our neighbor's house when I first took off LOL
Checked out this link , says does not fit trike .
Yep, I saw the same, slaw, but my local shop said it can be done. Out of curiosity, I went directly to HD and was told that, yes, it can be added to a trike BUT it invalidates the engine portion of your warranty since it was not designed with trikes in mind.
With that being said, I think I'll leave my girl's engine where it is and just tweak it with a Screamin' Eagle Stage I :)
That Stage 5 appears to be identical to my stage 4.. Exactly I think. They must have just changed the name since I did the stage 4. Mine screams along pretty well, but Kevin from DK with his stage 1 motor kept up with me on some 7% grades last year. And he was 2 up. I was not.
Kevin seems to be at the top of knowing how to upgrade, Trent. Since the Stage V is not covered by warranty if done on a trike, I am going to pass on the option. On the other hand, I have decided to either let Kevin do my Stage I when my warranty is dead, or go with a 110 crate engine, as was suggested by Gorilla. Either way, I hope to have her jazzed up before I'm too old to enjoy the power :D
Whatever his Stage 1 involves seems to work pretty well, from what I witnessed. We hauled up a several miles long 7% grade with 7 or 8 fairly wide curves. By the time we got to the top we were doing between 82 to 84 mph and he was right behind me. He said he was maxed out, but I still had a little bit left to pull out if I chose to do so. Very impressive since he had his BOB [ Babe On Back ] behind him. I still maintain I weigh more than the 2 of them put together even though he sez that is not true.. LOL...
Stage 5
Yep, I saw the same, slaw, but my local shop said it can be done. Out of curiosity, I went directly to HD and was told that, yes, it can be added to a trike BUT it invalidates the engine portion of your warranty since it was not designed with trikes in mind. With that being said, I think I'll leave my girl's engine where it is and just tweak it with a Screamin' Eagle Stage I :)
Will not void any warranty, don't know what you dealer is thinking, but who cares, its my dealer who has to warrant any work that would need to be done.
So if you want to play with the big boys, then you have to do more than stock, or stay on the porch as you have mentioned as it is not for you. Enjoy the rocking chair.
Sorry, you can't convince me that your stage 4 is the same as the stage 5.
Oh well.
I am certainly no mechanic but I checked out what comes with that stage 5. I seriously cannot see any difference from what I have with a 4. Does anyone know what the differences are? I am just curious as there was not a stage 5 available when I did mine. I kinda sorta blew up my original motor which was about a stage 2, and since it was under warranty, my tech talked me into the 4 because the labor was going to be covered anyway. I just had to buy the stage 4 parts. So I opted to do that rather than drop in a 110, or 120, or go to an S&S, which I also considered. I know 3 guys that have the HD 120 in their T-glides and are very happy with them, once they finally got them dialed in, which was quite a challenge for some reason. I got the full stage 4 for about 60% less than it would have cost if not for the warranty.
My dealer has no dyno for a trike, but my Buddy did the exact same stage 4 on his 2012 Ultra at the same time I did and we used his map to tune mine. He hit 114 HP and I don't remember the torque except that it was well over 100.
Of course you lose a lotta that HP by the time it filters down to the pavement on a Trike. If I ever blow this one up, I will most likely just drop in another motor of some kind.
That Freewheeler will be a screamer with that stage 5,, that's fer sure.
Here is what HD is calling a Stage IV these days-
It maintains the same cylinders/Cubic inches
Here is what HD is calling a Stage V these days-
92500038_TT
It includes all of a Stage IV, plus larger cylinders, bumping the cubic inches up to 110
118 horsepower and 130 lb of torque are great numbers. Should be a blast to ride! :)
At DK Custom we concentrate on doing Stage I upgrades (that will support all the way up to a Stage V upgrade).
The reason we concentrate on Stage I upgrades is that we can almost always get more power out of our Stage I upgrades than most folks get out of their Stage II upgrades...and our Stage I upgrades have never voided a warranty, and are much less expensive than a Stage II. Most performance oriented Stage II upgrades instantly void the powertrain warranty.
The other reason is that Twin Cams have a crankshaft that is notoriously prone to twisting (being ruined), and doing a Stage IV or Stage V without plugging and welding the crank is even more likely to end up with a twisted crank (if one were to play with that extra power).
That said, trikeharley's Stage V with his dealer covering the warranty for him...that is some sweet power.
My Stage I Tri-Glide is putting out 106 lb of torque, while more than most Stage II's, still a far cry from 130 lbs.
But 106 is enough for wheelies anytime I want. :)
Mufflers keep it from going over. :laugh:
"It includes all of a Stage IV, plus larger cylinders, bumping the cubic inches up to 110"
Hmmm... I did the big cylinders and fatter pistons on my stage 4 also.. ????
Reality2025
