I had a Hanningan Trike Kit. What do I have to remove to start to replace driveshaft and is the factory used in this driveline? Do I have to drop rear end or take the body off?
I had a Hannigan Trike Kit. What do I have to remove to start to replace driveshaft and is the factory used in this driveline? Do I have to drop rear end or take the body off?
The rear has to be dropped but, not to much!
Can you advise why it needs replaced?
The driveshaft u joint needs replaced. Bought my first motorcycle in 20 years (wanted a trike). Bought it in April. Had a tick at high speed which has turned into a slap on shifting but not on a load.
