Having to start the Triglide in neutral
If this does not work, though, take it in to the dealer... there is a known issue with the left hand control module (clutch switch) that causes this problem. Warranty Fix.
Had the same problem with the clutch switch. Dealer fixed it and now works fine.
That's what one dealer service writer tried to tell me, since I had Iron Braid lever covers and iso grips (larger diameter than the OEM grips. Said if it didn't correct it I would have to pay for the service. 20 minutes later I was riding out with everything working and a free warranty fix!:pepper:
look at your clutch handle
Big BPITA has anybody figured out how to get around it
i have a 2010 triglide . i found a switch under clutch lever has to be push in when you engage your
clutch.i removed the screws that were holding it to the bars.found i had move lever assembly
toward the center of the bike 1/2inch tightened down works perfect.
good luck viking
