Thank you SEE THROUGH BRAZ
Al, many thanks from me also for the TAT display I received in the mail today.
Sully, that looks super on on the back of your trike. :clapping:
Thank You
My custom TAT arrived today. ThumbUp I'll post a pic when I get it mounted.
Sully, I want to steal your mounting location. :)
Got another Tat in the mail today.
In case you don't get it :Shrug: Clowns to the Left of me / Jokers to the Right of me. Thats Old School stuff :laugh:
Question, Do you apply the Tats dry, Or wet the area with windex like i do with window stickers so they can be move around [Positioned] to a permanent spot...:Shrug:
They are like a static cling plastic strip, which can be removed and reinstalled moved and placed again. It works good.
Maybe Al will jump in here and explain it better than I can.
Matbe Al will jump in here and explain it better than I can.
Thanks... I have a pair and as of yet haven't taken them off the backing, ThumbUp
They can be readjusted fairly easy and remove easily nearly as easy as going on. If you need to re-position be careful not to stretch them. I had no problem readjusting mine, but yours is quite a bit longer so you might want to take a little extra care. That isn't a guarantee, but I pulled mine off several times and put right back on. I needed to do that simply as a test so I'd know if I wanted to get one for my trike eventually. Not decided what I want it to say just yet. :D
