Turndown Exhaust Extension W/ CSC
May 14, 2015
125
12
Sunrise, Florida
Anyone know if I can install the "turndown Exhaust Extensions on a 2015 viper kit? I believe they reinstalled the original tips on their redesigned exhaust, but not sure if the clearance is OK from the ground up
It's Christmas time and need to get Santa's list out before it's too late. :)
Just what it says. The clearance from the ground up. If you do not have anything to contribute, please refrain from smart comments.
Yes sir! understood Sir! I will rephrase since I don't know and wish to become more educated. . What is the necessary ground clearance from the end of the exhaust to the ground. Enquiring minds want to know.
My question is for someone that owns a csc conversion, will adding the turn down exhaust limit the necessary clearance needed so they will not scrap under certain road conditions.*
Are you runniing the Ground FX? If so you supposedly only have 4.2 inches of ground clearance with those I believe. So I'd measure what you have between your current tips and the ground to see how much you can turn down and maintain 4.2 inches.
One thing to keep in mind--on my Cobra XL they've cut the relief in the body square to match the stock Goldwing exhaust tips. Will it look funny if you install round turndowns?
My apologies, Your question just seemed more of sarcastic than helpful. My mistake for the misunderstanding.
No problem. That is the problem with the written word these days. Face to face the comment would have been understood. I'm guessing if you measure the height of a parking bumper, or speed bump in your area and you were 2" taller then you would be good to go. You could also measure the clearance of the appendage hanging under the Harley trikes. (think emergency brake)
I emailed CSC this morning and already got a response
"Any of the turn down tips can be used. Only the wide 3 hole outlet tip from Kury can’t be used because the cutout in the Viper body isn’t wide enough"
mtorcyclejoe
