Lehman Renegade LLS
Aug 17, 2014
56
26
Clanton, Al. USA
Anyone have a Lehman conversion on a late model Ultra?
If so:
  • What do you like about it?
  • What do you dislike about it?
  • How long have you had it?
  • Would you do it again?
  • Can you recommend a good Lemon converter in the southeast?
Thanks for your input.
Lehman Trike
I bought a 2007 Ultra already converted. I like the looks, especially the back end and the wheels and the longer wheel base. Dislikes: Tri Glide aftermarket parts may or may not fit. 96 cui was low on power, upgraded to 106 S&S.
Lehman LLS
If so:
The Lehman LLS is basically a Champion IRS with a Lehman body. I am a straight axle advocate but also understand the demand for a smoother ride that many have and the Independent Suspension will provide that.
Smooth and stable ride provided there isn't too much rake added and you don't over-inflate the rear tires.
Steering is not as quick as a Straight Axle due to the independent axles and too many moving parts prone to wear out, this includes tire wear due to changing camber with different loads. The parking brake that was customarily included in earlier Lehman's has been discontinued by Champion in all models.
I build them and have a straight axle model myself, but I would own one and ride it with confidence if it was set up properly.
Again, I am a Dealer/Installer so consequently I am biased.
Bullet Proof
