Motor Trike Trog installation Manual - Pictures?
Greetings, I am process of re-building my RK MT Trog Trike; I have the Installation Manual (updated September 2009) however it is missing "pictures" that are referred to in the manual....
By chance, does anyone have those pictures and would you be willing to share them?
Thanks, Mac....
Motortrike question
Thanks, Mac....
I find the Motortrike Company the most secretive and "don't want to help" people I have ever encountered. They offer little or no information on service or etc. They need to create a service manual for the Trog. Don't hold your breath.
As bad as I hate to say it,I have to agree with the above comments. MT is located only about 200 miles from me and has a dealer here. Because of that,I considered them for a trike conversion. However,when I called MT to ask questions,they definitely turned me off with their "Why do you want to know that" attitude/mentality. The difference between them and Hannigan is literally like night and day.
Love the looks of the Hannigan.
MT customer service is the pits. They need to send all employees to customer service school. They seem to be unaware that there are many competitors out there who care.
As far as I am concerned Motor Trike can forget it. I tried to get some one to talk to me about my reverse and the atitude they had was you bought it, paid for it, now it is yours don't bother us. I will never buy anything from them again.
Pics.
I agree MT is a real pain to deal with even their dealers complain. I would be more than happy to take some as built pics. for you if that will help. PM me if you need them
Other than completely disassembling the rear axle I have taken my Trog kit apart. It is a rather simple setup and someone with mechanical skills, tools and the time can take it apart and reassemble it. Using a digital camera to take picture of how the setup looks before disassembly, during disassembly will aid you in re assembling the rear end if you dont have a good memory of taking things apart
The rear belt pulley hub bearing has a bearing number that can be found online for a replacement. Best method to remove is to use a dremel to cut the bearing apart. Use the old center of the cut bearing to install the new rear pulley hub bearing if needed.
Heim joints that are apart of the attaching links from the swing arm, 3rd mounting arm and the adjuster for the belt tension can be found at McMaster Carr. The adjuster arm uses one right thread and one left handed thread. I found at 60k miles the lower heim joints were worn out and sloppy. I replaced all of my heim joints for around $125 from McMaster Carr with Stainless steel replacements
Air bags: if one leaks, Look @ replacements from JEGS or SUMMIT RACING. Motortrike air bags are expensive replacements. These Firestone air bags are not the same but these do work. They are slightly taller but are in the same compressed range as the stock Motortrike air bags and the Firestone bags work very well as replacements using less air pressure for ride comfort.
( ride tech 90007076 ) air springs and cost $60 a piece
Drum brakes and hardware are FORD Just use early 80s Mustang or Ranger pickup for reference.
Motor Trike - Never Again
Motor Trike is a P/O/S company run be anus orifices.
My M T wiring looks like a 3rd grader's science project
The swing are mounts frequently break off transmission cases (Harley too is to blame)
NO CUSTOMER SERVICE.
ShonaZiemb
