***DK Custom Products is Now Offering the Premium White LED Drop-In Headlight Bulb***
Jun 15, 2013
9,397
9,956
Red Banks, MS
Premium White LED Drop-In Headlight Bulb H4
Light up the road
Fits All Sportsters, Dynas, Softails & Touring
This is an easy install, just pull out the stock bulb and put this one in its' place.
Click HERE for more information.
Kelsey
Premium White LED Bulbs for Harley Passing - Driving Lights​
For 2009-2013 Harley Trikes w/ Passing Lamps
You will be able to see more, and people will see you better, day & night!
These super white lights also Match the DK Custom LED Drop-In Headlight.​
Fitment:
These are a direct replacement for HD Passing Lights, part # 68453-05
Fits 2009-2013 Harley Trikes that have Passing/Driving/Fog Lights that are not already LED from Harley.
This light was designed according to DOT specs, however, it is not DOT tested. Due to the brightness of these LED bulbs, you may need to adjust the lamps a small amount.
You can click HERE to see more information and pictures.
:pepper: Just placed my order and am looking forward to giving these a run. I will be travelling the whole month of August from east Texas, through OK, NM and CO. That should be a good test. I'm glad to see these at an affordable price! :clapping:
Dang. Wish these had come out before the daymaker lights. Of course the 14 and 15 trikes come standard with daymakers, in both the headlight and passing lights. Those are going to be ex-pen-sive to replace when the time comes.
Wonder if there's a way to replace the lights with these when that happens?
ThumbUp
I'm pretty sure you're going to enjoy the extra light on the road! :)
If you got the guts of a 13 or older headlight, AND changed the connection coming from the main harness, it would probably work.
Knock on wood, I've only broken 1 headlight (rock from a truck hit the lens) in 40 years riding on the street. Chance are good you will never need to replace your Daymaker that came on your '15.
Here's the before and after of the H4 LED replacement and the LED spot replacement. Rather dramatic as even the fairing shows more light on the white area.
DUAL LED Drop-In Headlight Bulbs Premium White H9 H11 - Harley
Fits Dual Bulb Headlights Found on Street Glide, Road King, CVO's & Others*​
CANbus Compatible!​
Clint
Also Available is a DOT approved Halogen Xenon bulb. Click HERE to see it.
Also Available are Matching Driving Lights. Click HERE to see them.
Kelsey
Just check out this difference!
You've GOT to get this headlight bulb!
*Fits ALL Harley*
Click HERE to see more photos and details!
Customer Review!
Great upgrade! Review by Drifter:
"This bulb works fantastic. Every bit as bright as a HD Daymaker! You wont be dissapointed."
(Posted on 12/17/2018)
Thanks, Drifter!
Go HERE for more photos and details!
Bullet Proof
