New Front tire
Jul 24, 2014
137
70
Atwater, CA
Thomas
Just put on the Avon fron tire. Only tire that is - Specifically designed for trikes. No milage yet - so cant report on anything. But it sure looks different. Not so much of a rounded crown - but more ' flat on top ' looking. Will report back......
Seems to ride well. Milage should improve, better than riding on the small surface area of the -- top on the crown. Once that wears down - its "gone".
In the picture that you show you have a very large crack in that tire. I would be returning that tire post haste to the dealer for a replacement. I believe that tire is going to come apart on you soon.
Well, hurry up and put some miles on that tire before my BT45 needs replacing. I'd like to see your take on how it performs and what mileage you get.
I became ver worried. Went out and checked -- Hard to tell from the photograph -- but it is actually a thin ribbon of rudder that runs across the tire. It occurs in two place on the wheel. (see picture) tire.jpg Part of the mold process, i'm told. Thanks for the heads up.
I've got 5 kmiles on mine and I love. I live and ride in the Arkansas twisties and this tire is better in every way than either the bt-45 or MPA in the ride and handling categories. Mileage as yet is unknown. However, as I've said before, the ride and handling are so much better that even if this tire only gets the same mileage as the others I will buy it again. Keep in mind that here all GW trikes average between 11-13 k miles because of chip and seal roads, and the constant twisties.
I am one happy camper. YMMV.
Got me worried. The original photo doesnt show it - but that is a fine ribbon of loose rubber across tire. (See new picture) Part of the molding process, i'm told.
I priced that tire at Iron pony yesterday it was $154. plus tax. I went with the MPA due to it being a new build and wasn't sure how it would hold up mileage wise but was a good looking profile.
That tread pattern looks a lot like the Michlen Pilot Active that i'm running on my trike. Keep us posted as to your wear and mileage as I'm going to have to start looking around for my replacement soon.
For the Harley Triglide guys; Avon hasn't made the wide tire for us yet. That is what their spokesman told me the other day. Hope they come out with one soon.:Coffee:
I read an article years ago (60's) in Popular Science or Mechanics that compared tire wear by each state. It all depends what filler they use in the asphalt which depends where they are located and what is more available and cheaper to the pavers. I remember the SE being very hard on tires due to granite in the asphalt they use. Florida, where I'm located used coral rock which is very soft and gave good tire wear. I have over 22,000 miles on my front BT45 and I'll probably get another 10,000. Of course we don't have the twisties like you do unless you count entrance ramps to interstate hwys.
louisianaJack
