NHBAGGER
400+ Posts
Would like to hear opinions on these, both positive and negative.
Can't Flintstone with running boards. Looks more like a motorcycle without running boards. Easyer to work on without running boards. Floorboards and highway pegs looks best IMHO!
yea : what he said.
I agree with all the above and with my leg reach I don't always keep my feet up at stop signs . it helps me to be able to move a little while stopped . not to mention the cost of them. IMO I say no.
Hi, Take a look at trike mid step - awesome steps. TomFriends that ride GW trikes have the running boards....like the looks on theirs, but not on a Tri-Glide. Too expensive for what you get. I say NO also!
Hi, Check these out. Trike Mid Step Thanks TomFriends that ride GW trikes have the running boards....like the looks on theirs, but not on a Tri-Glide. Too expensive for what you get. I say NO also!
I had the Lehman running boards on my 2003 Harley converted Lehman trike and love them, after totaling it out I purchased a 2013 Tri-Guide and had the Lehman boards installed along with a new header pipes to get rid of the excess heat, both worked great. I have since ordered a 2015 Tri-Guide and again having the Lehman running boards and new header pipes installed. May be expensive but I myself like to ride and if it is raining that does not stop me and the running the boards keeps the back of my legs dry unless I get the urge to plow thru a large puddle. I looked at the Road Smith boards and they looked to bulky so I stuck with Lehman.
Hi, Thanks for your comments. Boards would have to be customized with a notch out of them. We demonstrated the blue vulcan at least 5000 times at rallies and not a scratch on fenders. They make mount and dis mounting trike a lot easier.trike mid step you ought to design a set to be used with running boards and maybe a bit cheaper. running boards as it states keep you dryer when raining where as your mid steps don't do this but it looks like it does as you advertise. I would buy them if they fit with my lehman boards.
I agree they would need a notch cut out but you could supply a template for that so they could be mounted with the running boards as long as you knew what brand they have installed or are installing.Hi, Thanks for your comments. Boards would have to be customized with a notch out of them. We demonstrated the blue vulcan at least 5000 times at rallies and not a scratch on fenders. They make mount and dis mounting trike a lot easier. View attachment 25134Thanks Tom
Hi, Any shop that does conversions and installs running boards could do that. Our our shop could do that also. We are in Wisconsin though. Thanks TomI agree they would need a notch cut out but you could supply a template for that so they could be mounted with the running boards as long as you knew what brand they have installed or are installing.
