30 tooth pulley
hardheaded
300+ Posts
Dec 4, 2014
340
182
Florissant, MO
does the freewheeler have the 30 tooth transmission pulley like the tri-glide ? thought maybe HD might have kept the 32 tooth one on the freewheeler as it's a lighter bike. couldn't find this info anywhere.
This Service Supplement covers FLHTCUTG and FLRT models.
2015 Trike Service Supplement =
DRIVE ITEM NUMBER OF TEETH
Primary Engine 34
Primary Clutch 46
Final Transmission 30
Final Rear Wheel 70
Its only lighter by 136 pounds, its still pretty tubby.
OK, so what do you think 32 teeth are going to get you? I understand changing the drive ration; but for 2 teeth, I have to wonder if it would be worth the cost and what you gain or lose?
I am not as skeptical as I am curious on this modification proposal???
Springman
Springman
If you go to 32 teeth in the front like the 09 - 10 Triglides came with you get a pig which doesn't like 6th gear below 75 mph. There really isn't any fuel mileage savings in the extra 2 teeth, the fuel mileage between 32 teeth and 30 teeth is identical.
Well, that does not really appeal to me, especially for the cost and time......IMHO
Springman
you are right about being a pig in 6th gear. I even have a bigger cam and other stuff done to mine and it still acts that way if I put her into 6th before 75 mph.
that's with 2 people riding. Can get away with it with just me on it. I went with a mid-range cam for the type of riding I do.
Trustme54
