Have you changed out your headers?
WindyOne
500+ Posts
Dec 3, 2009
596
339
VA
Don
Working down my list replacing the stock headers is next after I do my lift kit. Looking at a time frame of January for this install.
What headers do you have that you replaced the stockers with?
Interested in ceramic coated headers to keep as much heat as possible off my leg.
Fullsac headers and mufflers --- love the setup ---and --- great people to work with --- I do not have any affiliation with this company buy highly recommend their product
With my 11 T/G I used Rush true duels [cat less] with Rush 175 slip-ons...
And a stage 1.. The stage 1 upped the red line to 64 hundred..
What I did find out is that the 175's were too loud for me, and did not have enough back pressure I lost some bottom end.. So I put a set of DK's Thunder Torque inserts on the slip-ons. A Ten minute job' That solved both problems..ThumbUp
On my 2011 I gutted the cat out of the stock headers. I was satisfied with it.
However, I did NOT want to go thru the hassle of gutting the cat on the 14. Instead I got the 2-1-2 ceramic coated Fuel Moto headers and have been very happy with them.
2014 with 6600+ miles and I have no heat issues with the stock pipes. Give it time to break-in!
Yes it was hot for the 1st couple of thousand miles. I do not get into traffic very much. B.O.B. is also not complaining.
If I do change I will use the fullsac cx pipes, 4" Reinharts, S&S A/C and do a TTS tuner. :pepper:
Bob :Dorag:
Either Fullsac pipe or a pipe from Fuelmoto will get the job done. The Fullsac sport pipe will get the job done a little cheaper, and still do just as good of job.
2nd day I owned it switched out stock for V&H Power Duals and their Monster Deluxe slip-on's for Tri-Glides.
Love the performance and sound. Added to that mix a FuelPac and ThrottlePac.
8~\o
MRB
