Safety Chain
wehrme
250+ Posts
May 20, 2014
225
119
Decatur, IL
Mike
My trailer receiver is so low to the ground, I'm having a hard time on figuring out how to keep the chain from dragging.
Chain has to remain the length that it is, to facilitate tight turning.
I'm thinking short bunge cord on each chain, so that it will remain kind of tight (higher off the ground), but will stretch out when it needs more length.
How are you guys accomplishing this?
Mike
If you haven't already done so reverse your stinger so that it curves up. If it is still too low get one with a longer curve until you have the height you need.
I take mine and cross them across the drawbar, left chain hooks to the right side and left to the right side, and still leaves plenty of slack for turns.
:Agree:
As a matter of safety, you should always cross your chains, and secure the hook with one hook over the receiver and one hook under. That's how we did it with the big rigs, still do it on any trailer I pull.
Stitch61
