I have a 2012 Roadsmith Trike and changed OEM tire at 7k miles to BT 45 reversed. After 8K miles noticing quite a bit of cupping, but plenty of tread left. Where should I start checking. Pressure is OK 36lbs.
I started a thread here awhile back about or more to the point asking why run a rear tire at it maximum psi when used as a front??
After all when you are using a rear tire as a front. It isn't under anywhere near the stress it would be if indeed it was being used on the rear.
Braking is nothing compared to the stress of acceleration.
If its max is 41psi loaded as a rear, most would run it at 36psi anyway.
Direction?? Not an issue.
So where did this run it at 41 as front come from anyway??
Without rehashing the whole past thread thing.
As a 2 wheeled double darksider for over 20 years.
Run it at 36 psi for comfort or at 41 if you want a bumpier ride.
That all running it at max psi is good for.
My Michelin MPA has 17K on it.
Run at 36 psi from day one, and still looks fresh.
Cupping is in my opinion a result of the roads conditions you ride on, and 36psi is more then enough.
Agreed! Three grand buys a lot of BT45's or MPA's! I may be in the minority but, I'm well satisfied w/my 4.5*rake, OEM fork springs, and my MPA, reverse rotation w/RideOn installed and 36psi.As Im not inclined to add the newer 180 Hannigan front end that Wheels likes so much at this time.
3 grand is just a bit much..
That is it in a NUT SHELL. Anyone needing an answer to the question , what tire to mount on the front and why, that comes up once a month. 300 times at least, read the above quote that explains it all. Problem is people ask the question get the answer and them try to. Rationalize it to Death. This works. Do it you will be Happy .Make sure the BT45 is a Rear Bias Ply tire and not a Radial "R" which has happened before, they are no where near the same tire. Bias Ply rear tires are Heavier, thicker and have stiffer side walls and can handle the 41 PSI no problem / I chose Reversed and I run the Michelin Pilot Activ Rear Bias Ply tire, in 130/70H-18 from Motorcycle Superstore for 109.99 shipped to your door OR 130/70H-18 BT45 for 111.87 Either one seem to work great on a Trike / but not a Radial as the Trike pushes to hard on the sidewall trying to roll the tire to its side. As a bike you lean into turns, as a trike you corner flat so a stiffer side wall is better... Just my opinion as its worked for me for years.... and thousands of miles.
The "H" is speed rating @ 130MPH
epper:
2012 GW CSC conversion - MPA Rear Bias Ply tire, in 130/70H-18 - at 41 psi with 2 oz. of Dyna Beads.
23 K on the last one and nearly 10 K on the current tire. No cupping issues so far.
Final decision: going to replace it and run 41lbs from now on. Me and my sweetie are worth a couple hundred bucks!!!
