good question.
Sep 4, 2013
769
121
Poplar Bluff, MO
Tom
I have posed this question to several of my friends and not gotten a good answer yet. maybe there is some one out there that can answer it.
if you have an auto shot gun with 2 3/4 in chambered barrel, and you buy a 3 in chambered barrel will it fit and if so can you now use 3 inch shells ?
Very Doubtful.
The Bolt has to cycle through the Receiver and don't believe those designed and produced for the 2 & 3/4 will accommodate the increased length shells for that Cycling to occur. Wouldn't open far enough to feed the 3" into the Barrel regardless of the Barrel's capacity to hold it.
the question was brought up because the receivers on Remington 1100 are not stamped 3 inch or what ever.
just the barrel. I guess you would have to look it up by ser # to be sure of what you had due to interchangeable barrels
Guess you could try one Shell and see. Should be able to tell by pulling the Bolt back and seeing if a 3"er would fit through into the Receiver.
Might be able to check with Rem by Serial #.
It is a Good Question.
One of those that makes ya go Hmmmmm ThumbUp
It is my understanding, after reading the FAQ on the Remington site, that on the 1100 the use of the 3" barrel is fine as long as you still use the 2 3/4" shells. I do this all the time. The 3" shells are not to be used in the 2 3/4" action.<br />
<br />
However, I have a friend who has been using 3" shells in his 2 3/4" action for turkey hunting only for the last 10-12 years and his 1100 is still in one piece, but he does occasionally have a failure to eject properly.
<div class="bbcode_quote">
<div class="quote_container">
<div class="bbcode_postedby">
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Livin2Ride</strong>
<a href="showthread.php?p=215052#post215052" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">It is my understanding, after reading the FAQ on the Remington site, that on the 1100 the use of the 3" barrel is fine as long as you still use the 2 3/4" shells. I do this all the time. The 3" shells are not to be used in the 2 3/4" action.<br />
<br />
However, I have a friend who has been using 3" shells in his 2 3/4" action for turkey hunting only for the last 10-12 years and his 1100 is still in one piece, but he does occasionally have a failure to eject properly.</div>
</div>
</div>
</div>Now that's the kind of post I like to read, facts instead of guessing. Way to many times people make posts that don't have any facts in them, it's just their guess. I like real facts.
Don't do it -- the remingtion is a good strong action but the 2 3/4 was not designed to handle the 3" shells!!!
thanks to all . You helped me decide what barrel to buy. <br />
<br />
I bought a used 1100 and used it at a meat shoot over the week end. it preformed poorly. I was able to hit the target but with very few pellets . (I used the house mossburg pump and still won 5 lbs of bologna and cheese) I measured the bore and found it to be .718. the barrel (mod. choke should be .711. this old barrel has a ding in the side of it and I think I see it in the bore as well. time for a new barrel.<br />
found several on e bay .
I chose a full choke which should be around .693 . a big difference. <br />
this one is 2 3/4 chambered. there was another that was 3" but it was a little more money. thanks, <br />
you guys saved me a few bucks.
Facts begin as Guesses.... ThumbUp
Maybe back in the caveman day's... We have evolved since then. Now we have engineers, computers and such not just sharp sticks to kill the beast with. Guns are used to set off explosive devices, best not guess. You learn things like that when you start reloading ammo. You guess there and things just might blow up in your face.
Hypothesis="Guess" based on observation, extrapolation, & experience.
Theory=Tested "Guess" that shows promise to be True.
Law=Fact based on proven Theory that began as a "Guess".
The basis of ALL Learning, Knowledge, Engineering and Science to this day.
No "Guessing"=Remain Cavemen.
Think I will continue to "Guess" ThumbUp
Think we are talking the same things just from a differing definition of "Guess".
Hope the above clears it up from my end.
Definitely NOT talking about some Idiot with a jack-a$$ Whim saying "Hey Ya'll, Watch THIS"
this is why I like to ask questions and compare answers before I guess. I call it research:wave4:
If your asking questions and comparing answers your not guessing your deciding. Big, big difference between guessing and deciding. :laugh:
Im guessing that by posing the question to smart people that I will get a good pool of intelligent answers to my problem then I can go into the d part of r&d and develop a plan of action that I guess will be the right one to solve the problem.........I guess ? :xzqxz:
anyway, I bought a used 2 3/4 inch (not the 3 inch one so I wont guess wrong and have a catastrophic failure) chambered twelve ga . barrel and Im going to blow the hell out of something hoping the pattern is smaller than it was before. I will let you know if I made the right guess.
I won 5 lbs of bologna and 5 lbs of cheese last time with the old barrel. Next time the 10 lbs of pork steak is mine !
I'll let the guessers have this thread, I've just heard to many story's of hunters guessing they was shooting at a deer and ended up killing their hunting buddy. :Shrug:
How does THAT have ANYTHING to do with ANYTHING that's been discussed in This Post ????
Feces Agitation Hijacks never end up well for ya Steve....
How many Times and how many Places/Forums is the count up to now ?
1. Let me guess... You've lost track of the conversation.
2. You know everyone here by their first name cause you say so.
3. Your next post will probably be an incoherent rant that makes no since to anyone. :laugh:
Does your room have rubber walls and do you even own a trike (with a motor in it)?
Easy Stevie,,,, Easy. (It's NOT a "secret" by any means)
Sorry and didn't mean to get ya All Wadded-Up or Ridin' the Cob. Just trying to help you not get the Big Flush once more from the Only Place you have left to go.
Also, You did not have Expressed Written Consent from me or Major League Baseball so your Re-Broadcast, Reproduction, and Other Use of my "Funnies" was Prohibited & had to be removed.
Since (as opposed to "Sense") you seem to have trouble comprehending my proper English,,,
That simply means-Bad Stevie. Bad. No Gold Star for you.
Seriously though, Just trying to help like Wheels and some others of us tried on the GL1800Riders Board did before the Mods/Admins pulled your Flusher (for the 2nd time-Lifer on the 2nd). Too late for There but not too late for here this 2nd time around.
It's All Good if You Let It Be.
By the way,,, My Room doesn't have Rubber-Walls (that would be Sweet) but rather is amateuristically adorned with several rattle-cans of Krylon
Quite Striking in a Simpleton sort of way. Wouldn't You agree? ThumbUp
P.s. Apologies to the OP. Just trying to help an Old Friend get on the Right Track.
our lodge has a meat shoot about once a month. have not tried to pattern it yet.
30 inch full choke.
the house gun at the lodge is a mossburg 500 and it wins almost every thing.
last month a 16 year old kid took home 2/3rds of the prizes and all the money rounds. his dad said (after the event) that he was on the trap team at school.
he was shooting a 870 super mag with screw in tubes.
the way the judges check the chokes is a 20ga shell has to slip in the end of the 12ga barrel. hard to tell how tight his choke was but it tested o.k.
I think we need to impose an age limit. after all my eyes are not what they use to be..
Cheating little Monsters :laugh:
Try shooting from the Post right next to him and talk some serious Smack.
Use your Maturity & Wisdom as a Weapon ;)
maybe make him shoot off hand with that eye closed standing on one leg unsupported using the barrel I just replaced.
just to make it a fair fight
bk65
