Having a problem with rear injector not squirting. The reoccurring DCT is "P95PE" that's missing the top leg of the "E" -- however, when readout shows "nonE" the top leg is there. Stuff I've already checked; Signal to rear injector will light a LED test light, but not an incandescent bulb type test light. Front injector signal WILL light incandescent type test light. Injectors will squirt when bumped with batt voltage. Fuel pressure is within limits (50 - 62 specified - 58 PSI actually). Good fire & compression -- not that that really affects the injectors. DID find some water in fuel, but drained tank & put in fresh fuel & blead injectors -- runs on front cyl, but rear is still dead. Fuel rail is clear, as is intake manifold.
Ususally when something bites my butt this hard, it's something simple, so thought I had it with the contaminated fuel. Starting to look like no doubt on the ECM. Does have Power Commander, but with PC out of the system, no change. Did get a DTC for "open head temp sw", but that was my fault for not pluging it back in after changing injectors. That's th eonly other DTC I've gotten other than the "P95PE" that doesn't show up in shop manual anywhere -- or on any DTC list I've found on line.
NM
NM
