Been meaning to post this for a while: I had a gizmo added to our 2012 Triglide this year at Daytona that has made the engine pull smoother and from lower RPM. All my earlier Electra Glides pulled well down low, but the 103" in this trike wouldn't come close. I ran into a vendor selling this gizmo that's sposed to make the bike run cooler and pull harder down low. Since I hadn't spent a dime at the show I bit on this guys line of bull. Normally I NEVER go for stuff like this. This time I'm glad I did. If it cooled the engine much, it's not a whole lot, but it took away that lean surge at real small throttle openings. And now I can pull 6th gear from 50 MPH on level ground. I get into it easy at that speed, but the engine is happy with it.
If you're interested, this guy can be reached at: Speedster L.E.D.
Lights
The site name is Nightrider XiED, 214.726.2641, ask for Ed Gamblin.
$135 if you install it yourself.
I believe it simply reduces the voltage signal to the ecm so it richens the f/a ratio slightly.
Plugs are almost slightly colored.
Phu Cat
Lights
Phu Cat
