Eurowing and EML trikes?
Any owner out there wishing to get a discussion group going on the above trikes.
We don't seem to get any response from this make?
Would be interested in owners opinions and anything else related to this make.
Right safe but have fun
Whats up guys , EurowingUSA will be introducing for 2013 some exciting news regarding the goldwing 1800 trike , harley sporster ,victory and harley touring . we wish all of you a happy riding season ahead . Marvin
Hi , i`ve just bought an Harley Road King EML Manhattan . The quality looks top notch. When i improve along with the weather , i will let you know how she rides .
The website could provide a bit more info; at least for the GL1800 conversion. Is it IRS? Does it include EZ steer? Available in kit form since there are so few dealers? Cost? Are the floorboards included? Paint match included? Is there an aux gas tank kit available? Just basic stuff most all other manufacturers include would be helpful.
Is it IRS? Their literature says semi independent. From working on mine it appears to be rigid. However it does ride pretty nice.
Does it include EZ steer? The Eurowing has an entirely new front end that sports a car tire. It is VERY responsive and easy to stear.
Available in kit form since there are so few dealers? They do not offer the trike in kit form.
Cost?
The price is pretty much in line with other trike kits excluding the front end. The front end was about $4,000 when we bought ours in '09.
Are the floorboards included? The floor boards are included. Be aware that they are a no-step floorboard.
Paint match included? On mine the paint was included.
Is there an aux gas tank kit available? To my knowledge there is not an aux tank available. However in 33K miles, it gets.only about one mpg less than our two wheeler.
Our Eurowing is a blast to ride. We did have a problem with the rear wheel bearings, but the dealer took care of it.
It did not have a trailer hitch installed. A friend helped me fabricate and install one.
I have triked my 2012 Level 2 Goldwing with the Eurowing Kit. It is fantastic, Handles better than any other trike I have owned ( I have had 5 different ones so far). All I can say is you have to drive one to see.
What is the "rake" with that new front end?? How does it compare to the 5.5 rake?
Ronnie
not sure about rake degrees. The frontend is not raked at the frame neck. The axle is moved forward at the bottom by about 2 inches. brake is relocated. this is what makes it easy to steer. It also uses a steering damper.
I have just swopped from a CSC with 6 deg rake to an EML with Easy Steer. I find the EML steering not half as good as the 6 deg rake. If you hit a joint in the tarmac road where the two lanes run together the EML will follow the joint, it is quite unnerving when it first happens and I find the steering far too light at speed.
In the UK, you don't get the option to not have the Easy Steer, it comes with the kit which can only be fitted by the dealer.
The UK EML kit does come as standard with floor boards and a paint job but no extra fuel tank on offer.
In the UK EML have just brought out a EML GT Martinique X which has re designed rear lights and fully independent suspension at a cost of £15.800 fitted which includes Easy Steer and full paint.
I hope this answers a few questions.
I think Endeavor trikes also needs a spot on this board seeing as Endeavor is the first and only universal reverse trike conversion company in the US.
Eurowing reverse kit
I installed their reverse kit. Put it in by the book. When finished It I couldn't get it in reverse nor would it go to neutral when the clutch was pulled. Also only find 3 gears. Clutch also adjusted by the book. Company rep couldn't give me any help. "All that worked before the install". I decided to pull it all and put it back to stock, but the small gear on the main shaft wouldn't come off, even with a impact.
jhlesher
