Getting ready to change the oil and check the differential. How in the world do you guys jack up tour trike? I can hardly get the pan off the bottom, let along check the rear end oil level.
I just typed a suggestion on another post 1 minute ago. here it is.
Maybe one of those scissor jacks from a car would do the trick. They have a lower profile than a floor jack.
Three ramps would just get in the way.
What flavor of a trike is it Robert?
On my Motor Trike, air up rear shocks, slide motorcycle jack under the rear to catch frame. Raise to first stop and then use floor jack under engine, jack up and put 6X6 under front wheel. Lower and remove floor jack. Change oil, grease driveshalf, and check rearend. And look it over.
Worn out joints and old bones won't let me work that low to the ground much. To change oil I run the front tire up onto a 2 X 6 which gives me plenty of room for the drain pan and filter access. Any other work needing done I pull out the big guns... After it's up in the air where I can get under the rear I use the scissors jack and 2 X 6 blocks to get the tires off the lift for removal.
I like your idea, but, it looks to me that the foot of your stand is not very wide. If your bike ever fell over.... I guess you could weld some extensions to the sides for better stability.
This helps getting the bike up in the air, but, it still won't let me get underneath. My bike has only 3" clearance. I think I'll look into someway to jack each wheel up one at a time and put a jack stand under each back wheel and keep the jack under the front wheel.
You use a scissors jack under the trike to lift it for the clearance you need.
I bought a motorcycle jack at Harbor Freight for $89. Best investment that I have made in a long time.
