• It appears that you have unread Personal Messages - Please check your inbox!
Flasher ??
RSW
Sep 8, 2011
1,104
29
Little Hocking, OH
Randy
When wiring a flasher into a turn signal setup, is this right? Run hot wire from the fuse block to the flasher. Run a wire out of the flasher to the turn switch. Then wires from the turn switch to the turn bulbs. Not having any problems, just learning for the future!! I also assume a flasher is just a automatic on and of switch??
stoney
