Reverse Motor
I have a 2012 Vivid Black Trike that was put HD shop because I am retarded and ran into the back of someone. I explained this in another thread a while back. Well the dealership called me back and said that my reverse motor was "out." They removed it from the bike and tested it. They now have another motor on order under factory warranty. Has anyone else had any reverse issues?
There has been some issues with the reverse motors but not many reported on this forum. If mine went bad and was not under warranty I certainly would not replace it in like kind.
Mine went out last Sat. and is going in today for repair. Appears that all supporting systems to the motor are working, just the motor is not. It did not trip the circuit breaker either. The last few times I used it before it quit I could tell it was getting weak.
Sam
I don't like the electric reverse on the tri-glide or a gold wing. I feel the after market reverse kits are way better... Just my opinion.
I feel Champion is the best in the under $1,500.00 market... with Baker being the best..but they're not cheap! :AGGHH:
I have a champion reverse on mine also and it works very well. Keep in mine though that with the Champion reverse you can be in reverse and a forward gear at the same time when you let the clutch out. :AGGHH:
I had my reverse go out on my street glide ; still under warranty though . Now I try to make sure I park in a way that I can just pull out , just so it doesn't get used too often !! Rediculous !
I hear you brother... It's like not wearing new shoes because you might wear them out. Or better yet... Not starting your car because the battery might die and pushing your car around town gets a little hard on the soul!
Now don't jump on me.. but I feel HD could have done a little better with the reverse on the tri-glide???? :Shrug:
If the Champion is not electric, how does it work?
It installs in the right end of the transmission. you put the trike in neutral and put it in reverse and use the clutch just like normal driving. Just have to make sure the transmission is in Neutral or it will be locked up and kill the motor.
Champion adds three gears to the end of the tranny shafts. Shift lever drops the third gear down between the two bolted to the end of the tranny shafts. Bike in neutral, drop reverse shifter to engage middle gear, you are in reverse. If the champion unit is engaged and you drop the bike into gear, you could do damage. Personal policy and practice are the only protection you have.
You would think there would be an inter-lock switch to prevent placing the bike in gear until the bike is taken out of reverse.
I have a Champion and it works great. The electric ones are also slow. Don't know why HD put an electric one on a $30,000+ bike.
Harley believes in cheap and idiot proof. They couldn't keep people from twisting the cranks on their 07 Touring bikes when they first increased the stroke due to lugging them. So the fix was to go with throttle by wire and torque management, warranty work dropped considerably once they controlled how far the throttle could be open at lower RPM's.
Get rid of Harleys junk reverse gear and have a Baker 6 Speed Reverse installed, Champion has a good Reverse, but Baker is the best on the market and with Baker there is no way you can get it in any other gear. when you get done backing up you just come back upm to first gear. I am a Trike Dealer and have installed several Reverse gears and Baker is fail safe.
I tried to get a Baker reverse for my conversion (2006 FLHTI), but it only works for the 6 speed tranny. I ended up with a Champion reverse, and have been very pleased with its performance...I can back up anywhere.
Friday I backed my 2012 Triglide into the garage. When I shut the bike down, It felt like it was still in gear. I checked to be sure the hand brake wasn't engaged, it wasn't. I started the bike, put it in 1st gear, slowly let out on the clutch, and it kind of jumped, but was freed up. When I put it into neutral, and tried to go into reverse, the reverse motor, just zingggged. It ran, but wouldn't engage. The dealer said it was a reverse gear that went. Wonder what I could or should have done different??
Well that motor hanging up in the gear was the first symptom I had before my motor went out. It did that 3 time and then it was all over. It never did trip the circuit breaker. I have been waiting for a new motor for a week and a half now, if I don't have one by Wed. I'm having the Champion kit put on and the heck with the electric reverse.
Sam
I have the Champion reverse and love it. I make it a practice to never leave the trike in reverse after I park. By the way the new Champion has a kill switch that if you put it in reverse and first gear at the same time it will kill the motor.
really I have to check out that new feature..
Why would they kill the motor. Guess that is "fail safe". I would settle for the horn sounding or some light on the dash, but that's just me. I have the Champion Reverse, no problems, just follow the correct process every time.
I still have found no information on where or how it kills the motor..where did you see this information at??
My reverse just started acting up. I put it in reverse (stock Harley electric), Then it surges. It moves a little and stops. if I hold the button it will go a little and stop go a little and stops. It has no power at all. Looks like dealer time, again! I am also having to ad a quart of oil about every 1000 miles. No smoking or leaks, have no idea where it is going.
Last time I went to dealer he put 42 psi of air in my REAR tires, left out emergency brake allen screw for locking handle in place, and my muffler fell off. I do NOT know about these wizards!
If you still don't have an allen screw, I would advise putting a screw in there with a head on it. They can tighten the original screw in there so far that it will drop inside the handle which locks up the entire adjustment. Happened to me twice. Others will say remove the entire mechanism but I still like using mine.
