Wrenching and parts
Mar 18, 2012
3
Lombard IL
Is there a technicle section. I am looking for shock bushings for my wifes 1998 Suzuki Intruder 1400 Vagabond Lehman Trike. The bushings are wore out. I can't find a source or even find out what kind of shocks the bike has.
Thanks in advance
If they're chromed coil over shocks with chromed shrouds top and bottom, there's a good chance that Lehman used the stock Suzuki shocks from the donor bike, but that'd be my best guess.
I know a guy who used a pair of motorcycle shocks that he bought at a boneyard and he used 'em on his T-Bucket hot rod, so there's no reason regular m/c shocks couldn't bear the light weight of the fiberglass body of your trike.
There's a member here who's also a Lehman rep, been in the business for many years, very knowledgeable........handle is "Lee H. Mann". If you contact him or he sees this post, he should be able to field most all of your questions.
Good luck and Ride Safe...........ThumbUp
Thanks in advance
Obiejuan,
If I am not mistaken, the shocks used for the 1400 Vagabond were progressive shocks and had a steel bushing kit that went into the shock eye-ends. Is it the rubber that has worn out ? If so, you need new shocks.
I can try to do some research for a progressive changeover number on Monday. I won't do that if you have already solved the problem though. PM me.
Almost all eye to eye Progressive shocks have bushing kits rather than specific bushings already pressed in. I would look for some Progressive 12s and get some stout springs... I use some 145/190 springs on my Progressive 12s on my Triumph 13.5".... they were on a KZ1000E previously. They are pretty stiff and would probably work quite well on a trike due to the added weight. I got kind of carried away when I ordered them and they are pretty stiff for a street bike but really helped the ride of the Triumph over the stock 12.5 shocks which bottomed when you hit a pot hole.
Gray_Ninja
