xv1100 home convertion
Status
Not open for further replies.
Jun 6, 2012
56
12
united kingdom
Hi all just a little insite into one of my home bike to trike convertions when i came up with this convertion it was aimed at those that would like to have a go at converting there own bikes to trikes on a low budget, so this is a very simple convertion but very effective that anyone could have a go at with a few pratical skills and a few power tools, in the UK quite a large number of trikes are home convertions and builds
in this instance the bike is a yamaha xv1100
next it was time to sort the swingarm to bike mounting and pivot points for this i would use high grade M16 rose joints with a 2mm pitch thread with M16 HT bolts
I then used two M16 stud nuts to insert into the main rails of the swingarm for the rose joints to screw into, the swingarm would then be sloted at the ends of the main rails and the inserts would be welded in
View attachment 5685 View attachment 5686
Next job was to make a bracket to mount the 3/4 inch brake master cylinder but becuse the xv had a drum brake on the back when the brake foot pedal was depressed the atached brake rod pulled witch was the oposite to what i needed to operate the hydrolic master cylinder,so i had to make the bracket for the master cylinder with a pivot point on it to do what i needed the brake rod to do, this would then be welded to the front brace of the swingarm once the brace was was fitted
after few more small jobs eg rear lights,forward marker light,hand brake cables and mudgaurds painted the rear end was again removed and returned to the shed to make a rear panel to cover the diff housing and axle tubes
OUTSTANDING!!!! ThumbUp I love home projects that work. You sir are either an evil genius or by far the sharpest tool in the shed. I am very impressed with your finished product.. nice work! :10:
Hi Memnoch, LOL you are much to kind with your comments but they are very much apreciated, glad you enjoyed the thread...... i do like to keep things basic and simple it leaves less to go wrong.:)
Zak
Status
Speedracer62
