WOBBLE
I would check several things that can cause this.
Tiers for cupping, suspension; forks, swing arm bushings, rear shocks. Engine mounts. Last but not least check for a bent wheel.
I put these in a order that use, easiest to more time consuming.
tire cupping is a symptom of suspension problems. I would imagine that a trike that age needs new wheel bearings, stem head bearing for sure, fork servicing with new seals and bushings.
FlintM
