wheels
I would consider giving them a call. Low price for good information.
What I did find was it is a 15 inch wheel with 4 lugs. Some folks use the 16 inch wheels with 4 lugs.
The off set is unknown if it uses any off set at all.
The wheels are designed for clearance.
Once you get the correct size and off set you can find something you like. The 4 lug wheel selection is getting smaller and smaller.
Motor Trike 4 lug wheels bolt pattern is 4 on 4.25, these fit early Mopar, darts and valiants. The 15 inch wheels are 15x7 with a 4 and 3/4 inch offset. You can special order wheels from Discount Tire and other wheel companies. Motor Trike has wheels for sale, I don't know about 4 lug since everything now is 5 lug, give them a call and ask for Richard.:GL1800:
louisianaJack
