Trunk light modification.
I have a 2017 'Wing' and want to change the outer brake light to a brake/running light like the inside lamps. Here is the problem. The plug, the ones that connect to the bulb receptacle, (this bulb receptacle has the standard 3 flat pit connectors), has only 2 wires, brake and ground. I have to connect a center wire for the running lights to work. I would like to use the OEM Honda horse shoe connector to complete this job. I cant find the part number from Honda (shocking), and can't find it on line... HELP!!!!
Welcome to the forum repost this in the Winger se tion I'm sure you will get help. Travel safe Fred
:welcome:FROM SOUTH
attachment.php
To the Trike Talk Family!
Hi George! Welcome to Trike Talk! Ask your question in the Gold Wing section and I am sure someone will chime in with the answer.
mudrock
