Trike Saddle Bag Kit- Order a kit and get a FREE Application kit (Good to 6/1/2016)
Jan 21, 2014
230
48
Illinois
Trike Saddle Bag Kit(NO HOLES)
SEE THROUGH BRAZ [SUP]®[/SUP] introduces a new improved process for attaching trike bags without drilling holes. We use our protective coating and a fastener system that withstand heat and cold and designed to hold up to 120 lbs. If you no longer want the bags on, removal is easy and does not damage paint.
In addition, we have found having the Triglide bags, with our process has lowered the temperature in the back area, by the passenger , approximately 10 degrees when moving. Yahoo!!!
WHY DRILL HOLES TO INSTALL SADDLE BAGS?
Don’t want to drill holes in your $35,000 trike? SEE THROUGH BRAZ [SUP]®[/SUP] has designed a kit to install these saddle bags without drilling holes, and will protect the paint underneath.
Location of bags is convenient for both rider and passenger without eliminating the comfort for the passenger. In addition, once they are installed, you are able to change seats without interference. Just remove the bag and readjust without any damage to paint. Easy as 1, 2, 3 and it is done.
Road and weight tested for durability.
SEE THROUGH BRAZ [SUP]®[/SUP] has the kit to install these saddle bags without drilling holes or worrying about damaging the painted surfaces. Once installed, the bags can be removed, adjusted or stored as needed.
Dieseluladstron
