Triglide gas tank fill up?
Put the nozzle in till just below the bottom of the fill neck. Run at about 1/3 speed on the fill rate. When it cuts off the first time, stop. You will only get 2-3 more ounces in if you try again and that is when it spills everywhere.
When filling, it will usually be up to neck with 1/2 gallon of space left. Then I just press pump handle Dink, dink, dink...etc to fill rest of way. When I encounter a crappy pump that has fine no control, I use the H-D official red rubber plug over nozzle to keep splash at minimum. No, I am not making that up. After causing problem, Harley sells a red rubber splash guard. An H-D bargain at only $19.99.
I just nurse the last 1/2 gal in like I'm poring Nitro.:laugh:
Here in NJ most pumps have the bellows type nozzle, one big pain in the :censored: Glad that the EPA came to there senses and that they now can be removed from the nozzles.ThumbUp
Need picture and part number. Thanks.
It all depends on the pump nozzel. Some nozzles let you fill to the top and some are really bad. Yesterday I had a bad one, I couldn't even click the handle without the gas splashing everywhere.
I remember seeing a gadget(not sure if it's the one Bikerbozo is referring to)on an episode of American Chopper. You put it on the end of the nozzle and then insert it into the tank. It's suppose to keep the gas from spilling all over the tank.
Its called ; Mc Cuff. I haven't tried it but i would think it's just something else I'll forget to put away before i drove off.:Shrug:
I agree with Ironhorsepilot. You just have to use tiny squirts until you see the gas. Never had a spill or gas splashes on the trike, and I have small hands. If we run into a pump that doesn't have goo control, just fill it till it cuts off. Not a problem! The best part of this story is, I only have to fill if I'm riding alone, so most of the time my sweet hubby is filling it for me! Thank you sweetie.
HD part # 99894-09
Blurb by HD re gas splash guard.
"The Fill-N-Go fuel tank adapter eliminates fuel spills and splash back during fill-ups, and reduces time at the pump. Just insert the Fill-N-Go over the fuel pump nozzle, and begin filling-up. When the pump clicks off, your tank is full, with no need to top off the tank. Kit includes Fill-N-Go tank adapter and a convenient storage pouch."
The best part of this story is, I only have to fill if I'm riding alone, so most of the time my sweet hubby is filling it for me! Thank you sweetie.[/QUOTE]
Oh hush up!!!! LOL! The only time my hubby will fill mine is if I let him ride it to the gas station! Won't admit it, but he loves to steal my trike.
In his defense, I usually pull up to pump and he pulls along side of me and I do mine, then hand him the nozzle.
Harleys #99894-09 and the McCuff are the same thing. It's the company that OCC built a special bike for.
What rino 2 said :Agree: ThumbUp
It should be stated that the advertised "pump until it clicks off" is a lie. You still end up witgh little Dink, dink, dinks while the air gets out, until actually full. It does stop most of the splash, but not all. When pump clicks off I usually have exactly 1/2 gallon left to go, so I just look at pump and do a little math.
Mine splashes out everytime I fill up. You have to wipe it off the paint because this crap will eat the paint. I made a splash guard out of a piece of 3/4-1" pipe foam insulation. It worked great but you can't see to top it off. lot cheaper than buying one. Jim
The "Fill-n-Go Fuel Tank Funnel" has never let me down! WELL worth the $19.95!!!! Once the nozzle clicks, I'm done. Never had any accedental spills. When I'm done, zip it up in the pouch and put it in the lower fairing storage till the next time I need it!ThumbUp
I bought the McCuff couple months ago....forget to use it. Depends on gas stations whether the outside gas tank gets splashed...some you can click, click, click and top off, others the gas goes "whoooooosh" all over. Be sure to wipe down before lighting a cigarette (lol).
Would you believe Oregon has a law that you cannot "top off" your gas tank (cars/motorcycles)...sticker right on the pumps. So far, the top-off police haven't caught me.....:censored: 'em!!!!!!
Barbara, you're living on barrowed time. :)
I hear there's a reward for anyone informing the "Top off Police" about people like you. :AGGHH:
If I get a pump with a bad trigger, I stop before I make a mess. If I get enoght gas in there to get 150 miles without running out i'm fine. I usually need to get off way before that.
Has anyone figured out what causes the slow fuel fill or if there is a fix for this problem? I have an 11 Triglide and fueling is ridiculous. On the other hand, my friend has a 12 and his trike fuels right to the neck the first time. Do the 2 wheel bikes experiance this?
Bill, Arroyo Grande, CA
2011 Triglide
My 11 Tri fills without trouble, The problem is if you gas up at a station that has the bellows nozzle, You have to pull the nozzle out a little and hold the bellows back with your hand, Some stations don't have the bellows contraption and without it you can fill the tank right to the top! [surface tension]
And at that point I have a feeling the tank holds a little more than 6 gal ...
the reason the govt. did away with the bellows pump is that the car manufactures re-designed the gas tanks somehow, so there isn't any need for that type pump. but many gas stations haven't removed the yet. guess we have to start complaining.
oh!! we do that well.
Basically same as IronHorsepilot. Than I rock it and slow fill it as high as I can get it. Depends also if others are waiting for me. Slow and steady, takes time to get it toped off correctly! Good Luck!
My son bought me the McGuff. I put in over the gas tank opening then insert the fuel nozzle. Put the gas in till is clicks off, then a couple of little squirts and slowly pull out the nozzle until all the gas has come out of it. the McGuff works great for me.
ledgin
