Should work the same as it does for the Tri Glide......so once you go through the sequence with the ignition switch and press both left and right turn signals simultaneously...... the turn signal indicators will flash once, this lets you know that the system has entered the Transport Mode. Of course your FOB has to be in range in order to start the sequence.
The Security System is still Active, so Red Light continues to flash. Transport Mode just disables the Motion Sensors, so lights don't flash and no siren if you have one installed.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
