Tourpac Relocation
Kurayakin (spelling) has a kit you can put on a regular bike, don't know about the trike though. I just drilled new holes in the trunk and moved mine back. Had to fill empty holes though. They were under the tourpak so I did not paint them, just sanded them down. First time I did it,I just drilled new holes in the round metal tubes that hold the tourpak on and moved it back that way. Felt it was not secure enough so I did it the other way.
I just installed my George Anderson tour pack relocation plate. I wanted this one because it worked with my Harley amp that is mounted under the tour pack and it gives you the option of 2 positions.
I will tell you it was not a easy job to install the plate due to the trike body, but now that it is on I can remove the 4 bolts to lift off the tour pack to get under if needed
Yes The kit from Kuriyakin will fit the TriGlide. Put one on. You have to drill holes in the kit rails, not the tour pak. Moved ours back three inches and had a new pad made for the gap. Had it stiched the same as the seat. Plenty of room on the seat for both of us now, was even able to put my backrest on.
Joe Henry
