Touring and Trike Owners DK Custom Products 4" Slash Cut Chrome End Caps Available!
Jun 15, 2013
9,404
9,944
Red Banks, MS
4" Down Slash End Caps, Rolled Edges
Show Chrome
The Perfect Finishing Touch to Thunder Torque Insert Modded Slip-On's
Easy Install, Instructions Included!​
These End Caps are made to fit on the end of the stock mufflers found on 2007 & Up Touring and Trike Models. They look MUCH Better than the factory end of the Slip-on's with a Big Round 4" Down Slash Cut.
It's easy to remove the stock baffles and replace them with Thunder Torque Inserts. Then, finish it off with these beautiful chrome End Caps. Not only will you have a Great Performing Slip-On exhaust, it will look Great too!
Over the years we have discovered that Harley knows what they're doing when they make muffler bodies, unfortunately they have to overly restrict them due to EPA regulations.
However, when the restrictive baffle is removed and replaced by the Patented Thunder Torque Insert, it produces a classic Harley sound AND out performs 99% of all aftermarket Slip-on mufflers.
Check out the videos and see more images HERE
Darryl
4 Inch Slash Cut Chrome End Caps for Touring Slip-on Exhaust
Perfect Finishing to Thunder Torque Modded Slip-on's
Optional W258 Thunder Torque Inserts
Learn more about the Thunder Torque Inserts that work with these End Caps at this LINK
FITMENT NOTES:
Fits 2007-Up Stock Harley Touring & Trike Slip-on Mufflers.
Installation requires cutting and drilling of your stock muffler bodies and should be an easy job for the home builder. Detailed instructions are included.
[FONT=arial, helvetica, sans-serif]Sold in a Pair of 2
Kelsey
[/FONT]
tony29
