What tool is used to access the rear wheel removal nut on a 2010 Champion Trike Kit
I just tried mine. I used a screw driver to remove the piece with 6 false screws (those are what you are probably trying to remove and just snaps off). There is an arrow showing you where to insert it. That held another piece that after lifting off exposed the lug nuts. If you are still having problems let me know as we both live in The Villages.This cover has several screws that look like it would take an Allen but there is a high point in each center that won't let the Allen go in the head.
Les
Those are security allens, need allen wrench with hole in center.This cover has several screws that look like it would take an Allen but there is a high point in each center that won't let the Allen go in the head.
