Rogue1
400+ Posts
I've been getting a rattle in the lower end primary side. It started several months ago. Worse after riding Back of the Dragon. At first it was only when I start to engage the clutch and only for a split second, but now it seems to be worse.
Also, not so much at start up, more at shut down. Of course, my first thought was compensator. Took a ride to the dealer and had the service manager give a listen. "yep" he said, "compensator". I drop it off Friday. Normally I would change it myself, but I have two weeks left on my extended warranty so, no. Under warranty they put the SE compensator on which is ok I quess.
If it happens again and I change it myself, I will go to aftermarket. I have been hearing a squeal when I disengage and engage the clutch since day one. No one could tell me the cause. Real noticeable when it's good and hot. Let's see if it continues after the change.
